跳转到主内容
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
856 个问题 查看全部
Lever will not go fully into reverse.
Lever will not go fully into reverse. Craftsman Lawn Tractor Automatic Trans. Model #917.272681. Goes forward fine but when going to reverse the lever only goes part way and tractor backs very slowly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hello, presumably, the drive pulley or clutch disc is worn out.
这个答案有帮助吗?
得分 0
添加一条评论
Reverse not working on my 2014 Craftsman Garden Tractor. Found frame to be cracked in half on both sides. The angle changed the reverse pedal travel so it does not engage.
这个答案有帮助吗?
得分 0
添加一条评论
I was looking for the same problem and came across your answer hollis… Thought you were just crazy….. til I looked at mine and saw the same thing….. THANK
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 132
