跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。型号为A1532, A1456
Boot loop after screen replacement
I have a friend's iPhone 5c and I changed the screen out for a replacement. I have done this several times on different phones with great results. This time the phone displayed a few lines of [NAND] dialogue, with the message "s_cxt_boot:88 sftl: error, unclean shutdown; adopted 863 spans". I found a blog saying to try replacing the frontcam/sensor flexcable, and the frontcam/sensor connector at the mainboard. I have replaced the first part, but cant find any instructions to do the latter. I have another phone that works, and could simply put the new screen on the other phone, but she has never done any sort of icloud backup and doesn't want to lose her stuff. Can anyone direct me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Jessica!
Yep, often error like these behave from an hardware error. This is the guide you need:
iPhone 5c Front-Facing Camera and Sensor Cable Replacement
A test you can do before buy any replacement is to disconnect, in this case, the front camera / sensor flex and without close the phone, try to boot again.
If the problem still continue, try also to disassemble the shield that hold in place the display assemble cables.
Cross my fingers for you..
这个答案有帮助吗?
得分 0
1条评论:
I have replaced the front assembly. I need a guide for changing the connector on the mainboard.
完成的
添加一条评论
添加你的答案
Jessica Paradis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 129
