跳转到主内容
PSP Pro Update Issue
hello, i've got psp 3004 by sony, it doesn't allow me to play games without entering pro update, when i open pro update it's just whole black.. no button works there, even removing battery only works if i want to do anything else
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try doing a system restore after backing any data up to a memory stick. Also, make sure you are connected to wifi when entering the update
这个答案有帮助吗?
得分 0
1条评论:
You don't need to be connected to wifi to use the pro updater. @Zohiab try to redownload the needed files for pro cfw then download infinity. Run pro updater and install it then run infinity to install it once then run it again and press left to select one of the two permanent firmware options.
Official Firmware (6.60/6.61)
https://darthsternie.net/psp-firmwares/
Pro Firmware Installer
https://www.gamebrew.org/wiki/PRO_Firmwa...
Infinity Installer
https://infinity.lolhax.org/
完成的
添加一条评论
添加你的答案
Zohaib 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 90
