跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 4 8.0 Wi-Fi(型号为 SM-T330)于 2014 年 4 月 23 日发布。它搭载四核 1.2 GHz 处理器,并配有 300 万像素后置摄像头。
Android is starting... Optimizing app 1 of 1
This is what I am seeing on my tablet after I press the power button to turn it on. It takes 6 minutes before this disappears and I am able to use my tablet. Any suggestions???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
I found a solution that need no flashing.My s6 edge plus behaved same way.I left like that because I did not want to lose some applications. On the third day it booted normal.
由完成的 分享
Same problem. Solved by uninstalling Stopwatch & Timer app: Icon has rows of zeroes and is magenta on top row, green on middle row and white on bottom.
由完成的 分享
Only 6 minutes? My Lenovo tablet takes 15 minutes "optimising app"
由完成的 分享
添加一条评论
6个答案
已选择的解决方案
Flash the Samsung firmware for your tablet via downloaded firmware from sammobile matching the model number and region of your tablet.
You need to do this with the tablet plugged in and booted to download mode. Instructions on how to do this are on every download page of every firmware on sammobile website.
This should fix your problem otherwise you need to do a factory reset probably.
How to flash Samsung Firmware: http://updato.com/how-to/how-to-install-...
这个答案有帮助吗?
得分 5
5条评论:
But why did this happen after 18 mos of use? Mine is the same, 6 minutes of optimizing.
由完成的 分享
The only things I can think of are:
- Bad app installation
- Android System Software Update is not optimized apps properly.
由完成的 分享
Hi Ben, I have the same situation with a Samsung 6 (cel phone not tablet), do you apply same web link shown above?
由完成的 分享
Samsung Galaxy S6? Same guide applies to that.
This guide is for pretty much all Samsung Devices and tablets from 2011 and newer.
由完成的 分享
The better suggestion for me is located below regarding BATTERY USAGE of the offending application...
由完成的 分享
添加一条评论
最有帮助的答案
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
这个答案有帮助吗?
得分 7
3条评论:
Thank you .. A good answer.
由完成的 分享
that was it.. ty
由完成的 分享
that was it!! your the only 1 on google or anything thank you for sharing ♥️
由完成的 分享
添加一条评论
Full load your phone. Turn off, disconnect from AC. Start and wait for the optimization process to come to an end. Check settings>battery for app using most battery. Deinstall that and reboot.
Update (06/03/2018)
Solution is from crackberry forum.
这个答案有帮助吗?
得分 5
3条评论:
This is accurate, and mine was not any of the apps previously mentioned (my fitness pal), but I checked the battery and it had the most use directly after starting. I uninstalled it and now my phone starts without any 'optimizing'. Thanks!
由完成的 分享
This was SMART...(worked for me and my tablet is an RCA, so should work for ALL TABLETS/PHONES)
I went into SETTINGS>BATTERY, then ignored SCREEN and ANDROID OS (which took up the most battery usage on my tablet. The next item on the list was HANGOUTS (which I don't think I ever use). So I went into SETTINGS>APPS and tapped on it, then clicked on DISABLE. When it finished, I rebooted the tablet and sure enough, the problem was solved. I then went back into SETTINGS>APPS and tapped on HANGOUTS again and ENABLED it. I then rebooted the tablet just to make sure the problem was solved and sure enough it was.
Thanks for the excellent suggestion!
由完成的 分享
This is a genius technique, highly logical captain. It works and it makes sense. Thanks.
由完成的 分享
添加一条评论
It was Zedge. Removed and instantly fixed issue. Thanks.
这个答案有帮助吗?
得分 1
添加一条评论
How can I remove any app when Android does not even start?
这个答案有帮助吗?
得分 1
添加一条评论
The only thing that seems to help is uninstalling the Google update on the RCA Galileo pro, but I want the Google update. Everytime it updates even though I did a factory reset, we go back to optimizing. I don't know what to do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kltilton 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 59
总计 47,084
