Difference between 15'' trackpad and 13'' replacement
I want to replace my trackpad because it no longer clicks. Does not work anymore. What part number should I get. Is the 13 trackpad compatible with my 15 Macbook Pro 2.53 Ghz unibody mid 2009?
The part you need for your Mid 2009 15" MacBook Pro is: 922-9035 Trackpad Assembly
The part for the Mid 2009 13" MacBook Pro is: 922-9063 Trackpad Assembly which is not compatible with your system.
Often the trackpad will fail when the battery swells. So you may need to first address the battery issue and you may find just adjusting the click plate is all thats needed if the click action is the only thing failing Vs not able to track your finger.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 122
