跳转到主内容
加入维修社区 - 创建账户
Nvidia Shield 平板电脑系列的新一代产品。该平板电脑于 2015 年 11 月发布,针对游戏进行了优化,并搭载 Android 操作系统。
Why my device not powering on?
1. When the charger plugged in, charging symbol doesn't appear at all.
2. I've tried different power outlet and USB cables and still no respond. My pc also not detect when plugged in with USB.
3. I also tried pressing and holding down the power button while the charger is plugged in and still the device not powering on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hi.I had this problem as well.I read around and what worked for me is holding the power button down for a long time,keep holding it down until it comes on.It eventually worked.Try doing it while plugged in also.good luck.
这个答案有帮助吗?
得分 2
1条评论:
I can't believe it! That worked for me! seemed like forever but was actually about three minutes. After releasing button I got battery emblem. then had to push on button again till it started. Thanks so MUCH! Paul
由完成的
添加一条评论
did you ever find a solution?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kora 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 1,695
