跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
How to remove water from LCD backlight?
Hello,
I have a iPhone 5c with water damage, the water is in the backlights, but the LCD and digitizer still work perfectly except for the watermarks in the LCD. How would I remove the watermarks without buying a new LCD assembly?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Also, is there any sort of take apart guide for the LCD?
完成的
If I remember correctly you can carefully take off the black backlight piece + desolder the 3 solder joints on the backlight ribbon connector. Then basically put another one on. I tried cleaning it, the best way is to replace the back black backlight thingy.
Something like this:
http://www.eddogo.com/lcd-backlight-back...
完成的
添加一条评论
1个答案
已选择的解决方案
You certainly could try to fix it, but honestly, anything water related.. I would just replace the front panel assembly. I trust that a lot more than hoping that water didn't slowly start creeping into anywhere on the phone.
The kit isn't too expensive, considering you can always use the tools again. Be aware that "This part does not include the home button, front camera assembly, earpiece speaker, or the LCD shield plate. You will need to transfer these parts from your old display assembly to your new part."
Here is the guide to do the replacement if you so choose to do it.
Good luck and keep us posted!
Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c.图片
产品
iPhone 5c LCD and Digitizer
$39.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 275
