跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Home button extension flex cable
Trying to replace a torn home button extension flex cable on an iphone 6s and can not find any online after extensive searching, short of just buying the digitizer replacement which obviously comes with one. Any ideas where I can find one? I can only find them for the 6s plus and the 6. I am capable of replacing the cable myself as I was the one who tore the cable while replacing the rear facing camera. Thank you for the help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
It use to come attached to the LCD shield which is what there for the 6, 6+
完成的
添加一条评论
2个答案
最有帮助的答案
It's built into the 3D-Touch sensor/backlight panel. You have to replace them all, there is no "just home button" extension cable to begin with.
这个答案有帮助吗?
得分 2
4条评论:
https://www.google.com/search?q=home+but...
This part cannot be installed in the 6s your saying? The picture of the link above is a replacement home button extension cable I purchased which was incorrect as it turned out to be for the iphone 6, not the 6s.
完成的
Right. You have to replace the entire backlight panel.
完成的
Great thanks for the help. More research and I see what you are talking about. I have the ability to buy just the backlight panel with the logic board flex cable built in to it. If I do so and install it with the original home button will I still have access to Touch ID so long as I don't try to update IOS, in turn getting error 53? Thanks again for the knowledgable responses.
完成的
Error 53? Are you talking about replacement home buttons bricking iphones? That is a thing of the past and does not occur anymore on updated iOS firmware.
完成的
添加一条评论
I also have been looking 6s extension cable but i couldn't make it. So I ordered assembly today about $20. I will tear it and put that cable from that out. Can not believe nobody sells that parts all around online market.
这个答案有帮助吗?
得分 0
1条评论:
I successfully replaced my iPhone 6 screen digitizer but the one I ordered did not have the extension ribbon for the home button & im pretty sure I cut it to allow the back plate and the screen to become separate so how do I replace that?
完成的
添加一条评论
添加你的答案
Ryan madden 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 3,296
