跳转到主内容
Power light continous green LED flashing for +/- 5 seconds, tv "dead"
Power LED when switching ON, flashes continuously GREEN for about 5 seconds and then steady GREEN LED - and no display on the screen - blank /"dead".
Under normal conditions, the GREEN LED will flash for about 3 seconds then "flip-flop" to RED status, i.e: TV is now in "standby" mode.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Locate the DG Board (Audio) and re-solder the DG Board connector pins of both power supply connector from the main Power Supply Board.
A "dry joint" was not allowing theDG board to fully 'diagnose and reset' on Power On...
( In my case the DG board was the TNPA4311 )
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jotburke 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 121
