跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Flashlight not working after screen replacement
So, a friend brought me his iPhone 5s because he knows I like to play with this kind of stuff.
His phone had the screen shattered. So, I ordered a new one, and tried to follow the instructions but I had a few problems during the repair.
1st, There was four connectors under the bracket, 3 of them came from the display (I think they were, digitizer, camera and earpiece and lcd) and one that I dont know.
The one that I don't know where it comes from was accidentally disconnected with my prytool and I had a hardtime trying to get it into place.
I finally got it into place and could turn the phone on. Screen ok, digitizer ok, touch id ok, front camera ok, earpiece, proximity sensor, everything seemed ok.
1 day later he called me. His volume button is not working properly, he cant raise the volume, only lower. And the flashlight is also not working.
I must admit I forgot to test the flashlight, but the volume rocker I did, and it was working just fine.
What should I do now?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
The 4 cables are Camera, Digitizer, LCD and camera+earspeaker
完成的
添加一条评论
1个答案
Hi,
The 4th connector was right above the other 3 connectors right ? then it was the camera flex. tell him to try his camera. Maybe you only damaged the few wires of the flashlight.
For the volume buttons, i don't know, you should check them
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
henzpedro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,760
