跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 个问题 查看全部
I removed the 3g module from my ipad 2 3g and wifi.
How can I restore my ipad 2 wifi+3g gsm when I have removed the 3g module. It stops about midway when installing firmware and never finishes with an error (1).
Maybe there is a chance to use it as an ipad wifi only?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
can you post a photo of the 3g module you removed?
完成的
添加一条评论
2个答案
已选择的解决方案
No, you will need to put it back.
Unless you replace the CPU and main flash from a wifi iPad so making it a true wifi-only model.
这个答案有帮助吗?
得分 2
2条评论:
Maybe you can show the picture , what exactly is to be removed to make it work just Wifi ?
完成的
Not removed, but replaced using the same part from a wifi only iPad.
The CPU is the chip which has Apple logo and A5 writing on it. The flash memory is the identical 2 large chips. On 16G models one of the spot is left blank.
BGA soldering skills required and replacing these parts can cost more than the device's worth. So it is hopeless.
完成的
添加一条评论
Yes u can use wifi only. But u must try fix logic board. U must terminate Some chip on logic board. And firmware update.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
zevaksarturs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 270
