跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
My phone will not turn on
i replaced my battery and put it back together. i noticed the home button was not working so i opened it up again and i fixed it. when i tried to turn on my phone nothing would happen. i made sure all things were connected and that it wasnt the lcd that was bad. please help i have tried everything and nothing works
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Have you tried combination of power button and home button?
完成的
Did you try unplugging the battery and reseating the front panel ribbon connectors?
Make sure you unplug battery first before replugging front panel connectors plug battery in last.
完成的
添加一条评论
2个答案
It sounds like you may have just gotten a defective battery
这个答案有帮助吗?
得分 0
添加一条评论
One thing to check...try using a small metal probe to "short" the two small contacts that the home button makes contact with on the charging port and try the solution that Raj Patel suggested. Typically, a hard reset makes everything better. If that doesn't work, I agree with Lukemacias1998 in that you might have just gotten a bad battery
Oh, you did try to charge the battery before trying to turn the phone on, right? It might just need to be charged.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
reptilian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 75
