跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
Does it matter which heat gun do I use for screen replacement?
How hot should the heat gun get? Mine is 250ºC.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
The heat gun itself is a little less important. You should use an infrared thermometer to know how hot your getting the device that you're working on. Like this
https://www.google.com/search?q=hde+infr...
这个答案有帮助吗?
得分 3
1条评论:
Thanks. That's helpful.
完成的
添加一条评论
最有帮助的答案
Hi,
It doesn't matter really no, how close you get depends how hot the surface will get anyway, so you need to know how to control that really, making it too hot will damage it, if it's not hot enough you'll have a hard time prying anything off. :-)
这个答案有帮助吗?
得分 3
6条评论:
But how do I know if it's too hot?
完成的
What are you trying to achieve? Glass removal or removal of the screen itself?
完成的
Screen removal.
完成的
Ok, you need to heat it up so it's a little hot (so you can still touch it, but only for a few seconds) but not too hot that you can't touch it at all, otherwise you risk damaging the OLED screen, this will soften up the adhesive enough for you to get under.
完成的
Or use a infored thermometer.
The easiest solution is using a hot mat or heat plate, as you can set the actual heat you need.
完成的
显示更多的1条评论
添加一条评论
Hey Mikk Rebase,
It doesn't matter which heatgun you use, you need like 900 watt. Thats enough.
这个答案有帮助吗?
得分 2
添加一条评论
If I have an iPad Air 2 and need to take the screen off to get to the battery etc which would be the best possible way to do this without damaging the screen it’s self?
这个答案有帮助吗?
得分 1
1条评论:
I replaced the lcd of my Sony Xperia Z1. The the soft and hard flexi cable tore. At the bottom where you slide the lcd to connect to the motherboard. Now the phone does not go on. Can that be the problem.
完成的
添加一条评论
添加你的答案
Mikk Rebase 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 7,962
