跳转到主内容
苹果的iPod Touch第六代于2015年7月发布。
Screen replacement did not work
I just finished replacing my cracked screen. Purchased the screen/digitizer through iFixit. The device turns on. The Home Button also works, but nothing happens when I touch the screen, which means I can't "slide" anything. There are also double vertical lines across the entire screen. Followed step by step! What did I do? Nothing ripped during replacement. I'm so afraid to attempt to pry open new screen to look around. I don't want to bust my new one! Any tips/hints would be greatly appreciated! Can't seem to find anything in the answers section pertaining to this issue -- just a white screen, which I don't have.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey Jaime Friel,
Have you already tried a Hard Reset? Hold the home button + power button at the same time for like 5 secconds. Your iPod will reboot and maybe this works.
这个答案有帮助吗?
得分 0
3条评论:
Unfortunately, I already tried that. Nothing.
完成的
Than you just need to heat the screen and try to take it out. It will not break, but just apply enough heat.
完成的
Maybe one of the cables is bent to the wrong way or something like that.
完成的
添加一条评论
添加你的答案
Jaime Friel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 134
