跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
How can I add a increase of internal memory?
Something like Android SSD cards, or
What hardware to I need to exchange to increase the internal memory? What is the name? What is the average price?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
You'll need BGA chip rework skills and special hardware/software tools to edit low-level data of the flash memory chip so the phone can accept the new chip. It's not as easy as an SD card swap for Android phones.
这个答案有帮助吗?
得分 2
1条评论:
Yeap, this is a company in china that can do this for $70 - $90 dollars. They basically work with the motherboard chips. It's not easy, you will need special tools (1k +), and adjust to the learning curve. This company could do the job in 1 hour for like 70 devices.
完成的
添加一条评论
最有帮助的答案
Unfortunately, there are no Apple products designed to have expandable memory. What you can do is connect your phone to the iCloud for extra space and automatic back up. Depending on how much space you need, you can purchase extra.
No matter what, it is safer to use this option in case your phone ever calls it quits. You then at that point can use iTunes to download whatever you backed up.
这个答案有帮助吗?
得分 3
1条评论:
Portable memory without wire,
a case with expandable memory,
are to me the best none tek solutions.
完成的
添加一条评论
Hey Royer Adames,
Sadly, you can't increase your memory.
这个答案有帮助吗?
得分 2
2条评论:
Normal repair people cannot, because they need a microscope (and other 1k + tools) and soldering skills.
完成的
True haha, I'm not that good.
完成的
添加一条评论
添加你的答案
Royer Adames 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,355
