跳转到主内容
Repair and disassembly guides for the Apple AirPort Extreme Model A1143.
Can the Wi-Fi Card be replaced?
My Airport Extreme base station (A1143) stopped working after a move across country. It does not appear to be transmitting a wireless signal on any frequency. It is possible to log in using the Airport Utility only if the computer is plugged into the AEBS. Nothing about the setup suggests there are any problems, although there was some issue with saving / loading profiles. This suggests to me that the wireless card is not working.
Is it possible to replace the card without replacing the logic board? The iFixit teardown suggests not, but I'm hoping there is a solution.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Of course, WiFi card can be replaced in this model (A1143)! I did it myself.
It's Atheros Mini PCI AR5BMB-0072TA. And as seen here:
http://www.vonwentzel.net/ABS/Dissection...
这个答案有帮助吗?
得分 2
1条评论:
Great research +
完成的
添加一条评论
添加你的答案
Luke Thomas Mergner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 3,805
