跳转到主内容
The economical version of the Samsung Galaxy S4, released in July 2013.
Why can I get no network access
Hi, having just repaired an s4 mini, which is locked to EE, I've put my normal EE sim card in the phone, but get no network access at all. When the sim is in my other Samsung, there is a good signal. Does anyone have any ideas what the problem could be? I can save contacts to the sim card, so I think the sim reader is ok. Could it be an antenna? or is there another part that could be at fault.
Many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Are you on the stock software?
完成的
Hi Ethan, yes. Standard software.
完成的
By no network access, do you mean that you don't get a signal, or it gives you an error when trying to call someone
完成的
Actually both. Circle with a line through it at the top of the screen. If I try to make a call I get a message saying there is no network connection.
完成的
Hmm do you have all the required antennas properly inserted?
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Hey Bigphilly71,
I would recommend you contacting your provider, maybe they can help you! Also, check your motherboard if everything looks alright.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bigphilly71 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 621
