跳转到主内容
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Accidental recovery mode when trying to turn it on
My alcatel one touch fierce power button completely broke a while ago so I had to turn it on my holding down the up volume button and plug in a charger and wake it up with the sensor on the phone. This morning I was turning it on and accidentally chose "Recovery Mode" instead of "Normal Boot" on the menu. The phone is stuck on the recovery mode menu and will not get off of it, even when I run the phone out of battery and try the up volume+plug in. Is there any way I can get off the the recovery mode menu
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I have fixed my problem, I took off the both back plates and put some metal in the power button slot where is snapped, it made the phone restart and get out of the recovery mode.
这个答案有帮助吗?
得分 1
添加一条评论
If your recovery supports adb then connect to pc and adb reboot.(if you did not flash a custom recovery like TWRP or 4ext then your recovery does not have adb.
If your recovery does not have adb then just disconnect and reconnect battery by using the ifixit guides.
这个答案有帮助吗?
得分 0
1条评论:
This didn't work, even when I disconnect and reconnect the battery it goes right back to the recovery screen.
完成的
添加一条评论
添加你的答案
mrfatguy227 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,153
