Coffee grounds in cup while brewing
Grounds coming out of K cup while brewing
I periodically insert a safety pin into the top needle....then I choose and run the "hot water" function....you should notice grounds in your cup. Repeat the safety pin procedure until the water is void of grounds. Others may use a straightened paper clip. Be careful.
BTW: I often do this during the brewing process....the brewing stops when you lift the lid.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 104
