跳转到主内容
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 个问题 查看全部
Dualshock 4 only works in PS4 safe mode?
I'm having problems with my Dualshock 4 controller.
If it's not plugged in with the USB cable, it does nothing. No lights when I press the PS button.
When I turn on the console, it says connect the controller with the USB cable and press the PS button. When I do that, nothing happens. No lights on the controller and no response from the PS4.
However, when I turn on the console in safe mode, the controller seems to work just fine.
When I try to connect the controller to my PC with the USB cable, it continually disconnects and reconnects.
I have tried 3 different USB cables, including the one it came with. This is the controller that came with the console.
What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
have you found a solution for that mate ? because I have this issue too
完成的
添加一条评论
6个答案
Might be the bluetooth chipset or the bluetooth antena
这个答案有帮助吗?
得分 0
添加一条评论
I think your Bluethoot antenna is broken. I have the same problem, tried with different controllers, and tried my controller on another PS4 without any problem.
Im considering to buy a wired controller, does anybody know if that will work out?
这个答案有帮助吗?
得分 0
1条评论:
I have the same problem. No solution. Going to the service centre tomorrow.
完成的
添加一条评论
I need help with this too.
这个答案有帮助吗?
得分 0
2条评论:
Hey, any update on if you were able to fix it ? I need help.
完成的
Yes. I had to mail it to sony. I exhausted all troubleshooting methods.
完成的
添加一条评论
A wired controller does work. Still can't seem to get a wireless controller to stay connected outside of the safe mode screen.
这个答案有帮助吗?
得分 0
1条评论:
when you got the wired controller did it work when it asked to connect to a dual shock 4 screen?
完成的
添加一条评论
I ended up having to mail mine in
这个答案有帮助吗?
得分 0
添加一条评论
# First try another controller and see if you still have the same issue. If the issue is still the same with a new controller, then read part two.
  1. If a controller only works in safe mode, this usually is not a controller issue, but instead is a console issue. The PS4 console only reads a controller through the the charge cable in safe mode. When the console is not in safe mode, the console reads the controller through the Bluetooth chip that is soldered onto the consoles motherboard. The only way to fix the issue is to have the consoles Bluetooth chip replaced. This video will help. https://m.youtube.com/watch?v=cTD3jjo1cr...
这个答案有帮助吗?
得分 0
1条评论:
If it were the bluetooth chip, wouldn't the controller work when plugged in via USB?
完成的
添加一条评论
添加你的答案
slickstretch30 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 45
过去 30 天: 175
总计 14,667
