跳转到主内容
加入维修社区 - 创建账户
The Nobis NB09 9” is a lightweight, portable internet tablet, released on January 17th, 2014.
Why is my nobis tablet stuck on the nobis emblem screen?
My nobis tablet is frozen at the nobis emblem screen and won't go past it I've tried everything from rebooting it and factory resetting it and it still doesn't go past the nobis emblem screen what do I do to fix the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
What if rebooting is not showing
完成的
添加一条评论
5个答案
已选择的解决方案
If your up for a little soldering you can try removing the battery for a while . This will cause the memory to clear and let it have a clean boot cycle. Whatever problem was causing the tablet to not boot will erased. However if its a hardware issue it will do the same thing after the mem wipe. This guild will help you tear down nd remove the battery .
Nobis NB09 Battery Replacement
Hope this helps
这个答案有帮助吗?
得分 3
4条评论:
It did not help mine one bit. I removed the wires leading from the battery to the board, pressed the power button several times, and after 1 hour I re-soldered the battery wires to the board. It is still hung up.
完成的
@hazycrazy You may have no other option than to do a factory reset
完成的
I have done all of this even after the factory reset it stays stuck on the go logo.. Does anyone have any ideas or advice for the next step
完成的
It's because the Nobis Tablet has a defect that causes the on board memory to short out and will not allow the system to boot. Best solution is to use it for target practice.
完成的
添加一条评论
最有帮助的答案
I've been dealing with this issue with 2 of them. not mine... the babysitter had 2 of their 2 children, and what I did was hold on the down-volume keys along with the power button, when powering on, until you get the Android Recover Console, and chose to wipe cache&media / factory reset, several times... let the "go" screen a long time, maybe reboot it a few times, until you get the screen "Android is upgrading..." it will also display "Optimizing application "n of n"" and will probably get stuck on some item of it... when that happens, when it get's stuck on a particular application let it there for a few minutes... and reboot the tablet again, as many times needed. One of them got through this operation... and the other one, I'm still fighting with it... same method... Sometime it goes as far as "Optimizing 26 of 38" it get's stuck there but then will not go further, and then when rebooted it will still get the "go" screen ....
Hope this helps anybody out there...
这个答案有帮助吗?
得分 4
添加一条评论
i just got a nobis 9 Dual tablet PC friend and everything that goes with it aswell and the frist day it was fine but the next day it start and went to GO and never left the spot at all and need help on it and what i can do aswell thank you from mary
这个答案有帮助吗?
得分 1
添加一条评论
Umm thanks hope this works!!
这个答案有帮助吗?
得分 0
添加一条评论
The question is on go and it has not left off of go so what can I do to fix it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeffrey Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 29
总计 6,831
