跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Phone won't turn on after battery replacement.
Hello there
Today I replaced my iPhone's front panel (backlight issues) and battery (didn't hold charge very well).
Everything went smoothly, more or less, but when i put it back together it didn't start up. I suspected the new battery was dead, but even after charging it for an hour it didn't seem to change anything.
Then i decided to disconnect the power ribbon and try turning it on while it's connected to a charger, which didn't work either.
However, when i connected the old battery it had booted up properly.
Is my new battery malfunctioning or am i missing something else entirely?
Note - with the new battery in the phone doesn't draw any power from chargers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Okay, so i got another battery (different seller) and the same thing happens. Chances of getting two defective batteries in a row are kind of low so i'm suspecting the problem is on my end, somehow.
The phone charges normally on the old battery, so the charging port isn't broken or anything
完成的
添加一条评论
1个答案
If the old battery is booting up fine then the issue will be with the new battery, probably a faulty part.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sebastianflorkow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,011
