跳转到主内容
E38 generation of BMW's full size luxury sedan.
7 个问题 查看全部
Abs icon at the speedometer light turn on
i have bmw 728i
the abs indicator is on at the speedometer panel ,what is the problem and how i can fix it?.
the speedometer doesn't work .
can i have manual book ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Take it to a parts store and get them to put a scan tool on it. The scan should tell you the problem via an ABS Problem Code. As there are many ABS codes and issues, this is the only way to pin point the issue.
Most Auto Parts Stores do this for free....
这个答案有帮助吗?
得分 1
添加一条评论
Wheel speed sensor or check your brake sensors
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Billy Halim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 164
