跳转到主内容
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
89 个问题 查看全部
Looking for Nexus 5x Schematics
I have a Nexus 5x that won't charge because of water damage. I opened it up and it looks like there might be damage on the quick charge circuit but I don't know what to test for. I need some schematics to see what parts are supposed to be capacitors and what parts are filters or resistors. I have tested the battery connectors on the motherboard and I don't have any voltage there. Also the place where the quick charge chip is heats up when it's plugged in. Does any one know where I can get schematics for a Nexus 5x? I can't seem to find them anywhere on the internet.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
forum.gsmhosting.com is where I have the most success finding phone schematics in searchable pdf format, but it’s pretty hit or miss and lots of old, dead links. I can’t find the 5X on there at the moment, but I’ve found many other useful ones in the past.
这个答案有帮助吗?
得分 0
添加一条评论
After more research I have found that most smartphone manufactures do not release schematics for there devices. So it looks like I am out of luck for finding schematics unless they are released. I will try to troubleshoot with my multi meter more and hopefully be able to find the broken connection or component.
这个答案有帮助吗?
得分 0
1条评论:
Hey I know I'm a bit late on this one, but I am now going through the same issue, and I need the schematics too. Did you eventually get it? If you did, could you send it to me please?
完成的
添加一条评论
添加你的答案
alexander 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 14
总计 3,178
