跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Top Screen has multiple issues.
Earlier my 3DS was involved in a rather unfortunate soda accident, and after cleaning it out and letting it dry for awhile it works relatively fine, but with a few issues
-Top screen is brighter than bottom and is unaffected by brightness changes in theme menu
-Top screen remains lit while in sleep mode while the bottom screen sleeps like it should
-Error message is given whenever I attempt to use exterior cameras
-3D mode had to be manually disabled via parental controls because the slider stopped functioning (remained lit despite my turning it completely down)
This is an original 3DS, not an XL.
Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Even though you may have let the DS dry out, the issue still remains that there was liquid spilled causing issues with the circuits. Something internaly has been damaged by the fluid and will need to be replaced.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Voidyskelecat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 128
