跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
screen replacement gone wrong
Iphone 6 plus cracked screen, screen plus digitizer replaced but accidentally miss installed the cables. screen turns black. Is there anything that I can do? other than buying another screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you please expand upon what you mean when you say a cable was not installed properly? It is very different if there was damaged to the cable on the screen vs. a connector on the board.
Thanks
完成的
Hi Owen, Thanks for your inquiry. I inserted the cable from the digitizer. on a different slot, it fits though but it was a wrong slot.
完成的
添加一条评论
1个答案
已选择的解决方案
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
When inserting a connector in the wrong place, it is possible that the connector was damaged. You have to closely inspect the connector, preferably with magnification, to see if any pins were damaged or if the plastic casing of the connector was mangled up.
Any damage to the (screen) connectors will require that you replace the screen. If the damage is on the logic board connectors, then those can be replaced via micro-soldering.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jeffrey Ramos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 142
