Accessory lights won't go off
Interior lights won't go off on my 1997 expedition
Check the switch that turns the dash lights brighter and dimmer. There is usually a position on the switch that when turned to the brightest setting on your dash lights can be turned a little more which causes the interior lights to stay on. You will feel a click in the switch at the point the interior lights will come on.
Good luck.
这个答案有帮助吗?
Check the door switches. It might be that one of them is broken or has a loose connection.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 477
