跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
Accessory lights won't go off
Interior lights won't go off on my 1997 expedition
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Check the switch that turns the dash lights brighter and dimmer. There is usually a position on the switch that when turned to the brightest setting on your dash lights can be turned a little more which causes the interior lights to stay on. You will feel a click in the switch at the point the interior lights will come on.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Tried that ! No luck
这个答案有帮助吗?
得分 0
添加一条评论
Check the door switches. It might be that one of them is broken or has a loose connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ray Belluomini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 586
