跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
Water damage. Battery okay. Drive okay. Looks like MagSafe board?
Hello. Water damage to this system '08 MacBook Pro 15". Opened it up and let it air dry for 4-5 days. Connect power cord and 'charging' light comes on, eventually turns green. Battery seems to charge. Push power on button and nothing happens. Pulled drive and can mount it and see it on another MacBook, so drive appears fine. Mother board visually appears fine, although may have a small burn/fry mark. No other apparent 'fry' marks. However, many solder points on the MagSafe are rather dark with one that is still the normal solder color. Found MagSafe boards on ebay for ~$10. Seems like a safe attempt to fix.
Does this seem a logical and/or likely issue?
Per local repair shop, it is important to get the appropriate MagSafe board. Reviewing several web search articles, I'm not sure exactly which model number to get or if substitutions are an option. Any advise?
My MagSafe board = 820-2361-02. Web search indicates this may be A1278. I'm leery of getting the wrong one and sending voltage or current that is too high to the motherboard. Sounds sub-optimal.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you consider cleaning anything before plugging the magsafe in to charge the laptop? The flowing liquid is only half the problem when it comes to spilling something on your computer. The deposits that are left behind, even after weeks of drying, can still be enough to short out components and render a MB useless until board level repair can be performed. From what it sounds like, something on your board definitely did short out and will need to be repaired. Your magsafe board sounds like it is working perfectly fine, especially if it is is indicating the charge state of the computer. This would suggest something outside the onewire circuit on your board is causing the issues.
Pictures of the areas you refer to as having "small burn/fry mark(s)" may be helpful, and one step you could try is removing the logic board and giving it a good clean down in either an ultrasonic bath, if you have one, or a soft brush and 91% or higher isopropyl.
It would be good to take detailed photos of the board before you do any such cleaning. While removing corrosion can sometimes get a board working (sometimes for the rest of that devices life, sometimes for a few weeks... water damage can strike at any time), if it doesn't, it's good to have pictures to provide a clue as to what components may need to be replaced later on. Once you remove signs of corrosion, it's just like cleaning up the blood at a crime scene, and it may be hard to figure out what happened later on if you chose to repair the board yourself or send it to get repaired.
So, remove the board...
MacBook Pro 15" Unibody Late 2008 and Early 2009 Logic Board Replacement
...take pictures (especially if you see any marks that look out of the ordinary), and then clean it. If that fixes your problem, fantastic, it may last forever, it may not. If it doesn't, look into performing a board level repair or having one done by a professional (or get a new logic board).
If the magsafe board is bad, replacing it will probably damage even more of the main board if it isn't already damaged.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bob Little 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 136
