跳转到主内容
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
89 个问题 查看全部
Bricked Phone help me bring it back Alive
please guys anyone help me !
what can i do to my phone i was facing some problems with it and my friend tried and failed by loading a wrong boot on it so the phone is worthless right now it's not starting or giving any respond when i connect it to my laptop and i didn't get the chance to use it i only used it for a month .
Please any suggestions or ideas would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
i'm using a converter because in my country we don't have the proper cable
完成的
Hi, how is everyone doing? I also bricked my device. It's also not able to go into fastboot. It's a moto G X1032, and android 5.1 was installed on it before flashing. I tried using file from this link https://forum.xda-developers.com/moto-g/... to revive it but it failed. please help, thanks.
完成的
添加一条评论
2个答案
You likely just need to reflash the factory images. Just boot into fastboot by holding volume down and power, and flash the factory image from here: https://developers.google.com/android/ne...
If your phone shows QHSUSB_BULK in device manager, it is much more complicated. It seems that there is no unbrick method for the 5X currently if you are stuck in that mode.
这个答案有帮助吗?
得分 0
10条评论:
i pressed volume down and the power button put it didn't do anything
完成的
Plug the phone into the computer, what do you see in device manager?
完成的
it says unknown USB Device
完成的
Can we get a screenshot? Also what cable are you using.
完成的
完成的
显示更多的5条评论
添加一条评论
So, what was the final chapter? Could you turn it on? I have this issue: sending sparse 'system' (524289 KB)... FAILED (too many links)
这个答案有帮助吗?
得分 0
1条评论:
try a different usb port
完成的
添加一条评论
添加你的答案
Mostafa Heikal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 5,403
