跳转到主内容
User-centric 15" Asus F553M notebook laptop. Released in 2015.
18 个问题 查看全部
Broke charging port inside the case..
I have a asus f553ma hh24tq laptop, need to replace the charging port..Is this something you can do ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
You mean the DC jack?
You can do this.
most of the time you can replace the DC jack.
Sometimes this is soldered to the PCB.
send us a picture so we can look.
Opening a laptop is not that hard..
Kind regards,
kevin
这个答案有帮助吗?
得分 1
添加一条评论
Same issue here. Have laptop open, need the dc jack. Soldered to the mobo. Not sure how post pic. Model is F553M. Laptop will come on but screen is blank, if you mess with power connector you can get the screen to come back on.
这个答案有帮助吗?
得分 0
添加一条评论
How... Did you manage that?
And to answer your question, look online and you should be able to find a replacement. It's a standard port, so with a bit of soldering, you should be able to swap it out.
I am not liable for any damages you do to your own devices. Attempt my fix at your own risk
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sparky247 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 431
