跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
How to remove glue from under the motherboards shield
I am replacing a screen on my ipod touch 4th generation and the guy who refurbished it before glued the shield to the motherboard if you could help me i would very much appreciate it,
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Is it actually glue, or is it just really sticky adhesive tape?
这个答案有帮助吗?
得分 1
2条评论:
By default there is adhesive sticking behind the metal shield above the motherboard. They come like that. It's just really sticky adhesive tape.
完成的
How do you get that up
完成的
添加一条评论
I dont know all i know is it will not come up
这个答案有帮助吗?
得分 0
6条评论:
The process I use involves a variable temp heat gun set at anywhere from 180-200 degrees to help loosen the adhesive and slowly work the shield up using a ESD safe plastic like spudger to help seperate the two. It take a bit of work an patience but it will come loose.
完成的
Will a hairdryer work too
完成的
That will help loosen the adhesive but may require more time with applying heat whereas I do not believe hair dryers reach the temps necessary for what is required. If it is all you have available though it is absolutely worth a shot.
完成的
Because if you used a heat gun for too long wouldnt it melt the motherboard or at least damage it
完成的
As long as it is set between 180-200 it will be okay. I wouldn't leave it blowing on it directly for a extended period of time, but enough till you feel the adhesive loosen. I personally use a custom made hot plate that is set in that range for all my device repairs that have the screens adhered on. If monitored and done correctly and cautiously, the device will be perfectly fine.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Jimmy Robertson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 180
