跳转到主内容
Can I use early 2015's battery on a late 2013 model?
I'd like to know if is it possible to use early 2015's battery on a late 2013 model, and if anyone already did it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
The 2015 MacBook Pro Retina uses an A1582 battery
Compatibility
Models Model Numbers
MacBook Pro 15.4" 2.2GHz Core i7 (A1398) - Mid 2015 MJLQ2LL/A
MacBook Pro 15.4" 2.5GHz Core i7 (A1398) - Mid 2015 MJLQ2LL/A
MJLT2LL/A
MacBook Pro 15.4" 2.8GHz Core i7 (A1398) - Mid 2015 MJLQ2LL/A
MJLT2LL/A
The 2013 MacBook Pro Retina uses an A1493 battery
Compatibility
MacBook Pro 13" Retina Display Late 2013
2.4 GHz (Late 2013)
2.6 GHz (Late 2013)
2.8 GHz (Late 2013)
MacBook Pro 13" Retina Display Mid 2014
2.6 GHz (Mid 2014)
2.8 GHz (Mid 2014)
3.0 GHz (Mid 2014)
这个答案有帮助吗?
得分 2
2条评论:
Will it fit though? They look identical.
完成的
They look similar but far from identical. Look at the width of the outer modules.
完成的
添加一条评论
have installed A1582 battery to MacBook Pro 13" Retina Display Late 2013
- no issue, and hold a charge
这个答案有帮助吗?
得分 1
2条评论:
tried it, it seems to be OK but when you stress CPU and GPU when on battery only (no charger) than it tends to shutdown (hard)
So, NOT COMPATIBLE
完成的
The answer is *almost* helpful. It does 15" for 2015 and 13" for 2013. But what about compatability between 2013 and 2015 15" ? In 2017, Apple replaced the battery in my late-2013 15" Retina, and 18 months later that battery started swelling a little - now swollen enough to pop the flap at the back hinge.
完成的
添加一条评论
Hi
i just install A1493 Battery To Macbook Pro 13 Retina 2015 Was No Problem Charging And Discharging
Original Battery Was A1582
so A1493 and A1582 Compatible
这个答案有帮助吗?
得分 0
3条评论:
Well give it a month and tell us then.
完成的
This still hold true?
完成的
So, NOT COMPATIBLE
完成的
添加一条评论
添加你的答案
gianluca pertosa 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 28
总计 2,425
