跳转到主内容
The Asus MeMO Pad 10 features a vibrant IPS display with a 1280 x 800 resolution.
19 个问题 查看全部
Why does my tablet keep turning off
Why does my tablet keep turning off by itself after being on for awhile
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
Most likely your battery is going bad. And replacing the batteries on those is not easy at all. If you dont have insurance on it, or the warranty is already voided, i would think about buying a new tablet. I would try to contact asus though, see if its still under the factory warranty or see what they would charge to fix it. Hope this is helpful.
这个答案有帮助吗?
得分 0
添加一条评论
This a problem with a cover with a flap that covers the screen. Remove tablet from cover and see if it stays on. I had the same problem which is now solved.
这个答案有帮助吗?
得分 0
添加一条评论
Hi I’ve got the same problem my asus tablet screen P00C keeps shutting itself off every few minutes periodically, here’s what did
I checked sleep mode, its set to NEVER Sleep
I put it on Safe Mode, it doesn’t appear to be a third party app, but did make the turning back on more quickly
I checked all the settings
So I don’t know about anything else that causes it
这个答案有帮助吗?
得分 0
1条评论:
Actually just tried Asus cover > automatic sleep/wake
完成的
添加一条评论
添加你的答案
Jerry Bevacqua 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 7
总计 3,443
