跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
425 个问题 查看全部
Need to get to the front panel whirlpool washing machine wwdc 8420
Hi all
The button on the front panel of my whirpool wwdc 8420 has come off so I cant press start/stop
Can anyone tell me how to get to the front panel from inside please?
Many thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Perhaps you might start by removing the top panel; usually it will pop off the top and is clipped in. Under that, it should become more evident how to proceed further. perhaps take a picture for us once you get there?
这个答案有帮助吗?
得分 0
1条评论:
start up swicth is blinking after set to operation
完成的
添加一条评论
Ensure machine is isolated. Take the top-off, which is held in by 2 philips screws at the back. Then depending on the model there may be a bracket support plate at the front which needs to be removed, either way the front display/control panel is held in place by 2 screws on the top of the machine and either 2 or 3 screws through the front of the soap dispoenser housing. The timer/display module is generally held in place with plastic clip-mouldings. The buttons are located behind the circuit board…generally.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AlexKnight 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 1,084
