JBL Synchros E50BT Broken Charging and Audio Port
JBL is wireless but also can be used using a wire, and I dropped it, with the wire on and broke the charging and audio port now I cant charge it anymore. can you help me fix it? :(
Update (07/02/2016)
my broken charging port looks like this
and the normal thing should look like this :/
2条评论
Have u fixed it? And how?
由 Just Me 完成的
I have disassembled the left ear speaker and have pictures and can take measurements of the 2.5mm jack. There is a 4 pin plug which has leads from the jack PCB board, blue, red, green, white. The PCB holds the jack socket and is mounted to the ear housing with 2 small screws. The jack socket is SMD mounted with 5 pin pads - 2 at the top flanking near the insertion, 1 left middle, 1 bottom right, 1 bottom center. https://i.imgur.com/tVm45Bv.jpg
I am going to call JBL to find out if I can obtain the replacement PCB.
由 Proficient Solutions 完成的
