跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Fast Charge doesn't work anymore...
The Fast Charge feature does not work on my Galaxy S6 anymore. I tried different cables and adapters with Fast Charge support, but my Galaxy only says "Cable charging" and not "Fast charging". Hope that someone can help me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Check charger port if it's dirty inside, if yes try using a toothpick / tweezers or something equivalent to carefully clean the charger port of gunk.
完成的
Thanks for your answer, lots of dust in the port but still doesn't work :(
完成的
Is the option in settings still turned on for fast charging? ( Settings > battery > scroll to bottom)
完成的
添加一条评论
3个答案
I would update the software on the phone first thing then purchase a new complete fast charger like this in retail box so you know it is oem samsung charger http://www.sfelectronics.biz/not-7-samsu...
这个答案有帮助吗?
得分 0
添加一条评论
I have the same thing I replaced the motherboard and it fix it
这个答案有帮助吗?
得分 0
添加一条评论
Ensure that Fast Charging is enabled in settings. To do so you must go to Settings>Power Saving> Fast Charge and make sure it is checked. If that doesn't work then clean out the charging port. If that still doesn't work then try another cable. The cable should be thicker in shielding. Ensure the cable isn't frayed, bent or damaged in any way. I find in my own experience that charging cables over 3 feet long tend to be shoddy at fast charging. Ensure your charger brick actually works by charging another device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lukas Hauenstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 737
