跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Why can't I get a display
I recently replaced my iPad 2 digitizer and even thought with a bad digitized I still got a working screen with light so now that I replaced it I'm not getting a screen I would do a hard reset but there's no way of knowing the home button is working since it has no cords attached to it or anything I'm really stuck here please help but I know it's on cause if I plug in the charger I'll get the charging sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I would double check your LCD connections. It sounds you have a loose connector not making good contact. But make sure you power down the device or disconnect the battery before checking your connections you don't won't to short anything out.
这个答案有帮助吗?
得分 0
2条评论:
I let the battery die down and when I plugged in the charge the battery sign comes up like when it's dead so I know it's not the lcd so I let it charge but it seems now it will still not show the screen but I plugged the charger in again and I can hear the charging sound I'm not sure what to do please help
完成的
After you let it charge do you see any image on the screen? if not during your iPad repair the blacklight components could of burnt out just by what you're describing.
完成的
添加一条评论
I think im having the same problem. While charging a dead battery the screen is bright and functional. However it goes completely black, no activity at all, after booting. Any ideas?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lateef ambali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 130
