跳转到主内容
The LG G Watch R is a Smartwatch manufactured by LG that includes many features of a Smartphone and a full-circle P-OLED display.
26 个问题 查看全部
My watch is not charging at all
My step-dad recently gave me his LG G Watch. He said it's about 2 years and has been sitting for a while unused, but was working when he stopped using it. It's been on the charger for at least 2 hours now, but still no charge. Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
7个答案
最有帮助的答案
You may need to change the battery, see other answers but try a factory reset, while keeping it on the charger press and hold the side button for a minute or so until you see the LG logo then let go, it may then do a reboot. If not - when you get the LG logo swipe from 11 to 3 and you may get a 'bios screen' at that point press the 0 symbol at the bottom of the screen. Odds on it will require a replacement battery I think.
这个答案有帮助吗?
得分 1
添加一条评论
please send the photo of charging port.
1'may be charging port is wsated
这个答案有帮助吗?
得分 0
1条评论:
I'm new to this. How do I send photos?
完成的
添加一条评论
battery need some low voltage shock then it will work
这个答案有帮助吗?
得分 0
1条评论:
How do I accomplish that
完成的
添加一条评论
I too have a the same problem as the rest of the countless users here on iFixit as well as on other forums including XDA. Even though the G Watch R was the best looking rugged smart watch to be released as the time it seems most shittiest of products. Thumbs down to LG.
My watch worked fine, until it decided to die all of a sudden while on my hand, thought there is no juice left,but even though charging/changing cradles and chargers it did nothing. Pressing the the side button makes the screen blink with the charging battery icon but thats it.
The strange thing is when u leave it in cradle over night, i mean over good 4 or 5 hours left to charge, it decides to come back to life. But stays on only while on the plugged in to power, the moment you take it out same problem, it just dies.
The charging ports are, clean. The side button and touch responds (when it decides to switch on), i even once did a factory reset, also i have removed it and serviced it with 90% alcohol.
Im really really frustrated with this bloody piece of junc, please advice me what i should do next.
Where i live, there is no eBay access, even they do, chances are high it gets stolen in domestic post.
Please help....
这个答案有帮助吗?
得分 0
1条评论:
I had the same issue, how you fix?
完成的
添加一条评论
I had a problem where if it would charge, it would rapidly switch from watch face to clock motion charge status... it would sit at a charge number then switch back to watch face, then switch back to beginning charge again... and cycle until it was dead...
I ended up replacing the battery, but that alone did't fix the issue. It did start up w/ a charge initially but never fully charged and ended up being a brick again regardless of what button i pressed or did.
I then decided to use a multi port USB charger... I chose the 2200 am charger ports instead of the 800 or so that came w/ the unit... n battery went to charge mode and now fully functional. I may just leave my watch in the kitchen where the charger is instead of up in the bathroom... at least I got a smartwatch back for less than $30... thanks for everyone's posts in troubleshooting.
这个答案有帮助吗?
得分 0
添加一条评论
where can i buy lg g watch r battery? i ‘m in malaysia i bought new dock charger but my lg g watch r seemed to be having battery problem. Please tell me where can i get it.
这个答案有帮助吗?
得分 0
1条评论:
Amazon or ebay
完成的
添加一条评论
Saw the post above regarding high amp charger so I tried my ASUS tablet charger and it’s actually trying to charge!! Will see if it manages to fully charge and then see what happens :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michelle Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 9,919
