跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Back-light fuse pops as soon as the battery is connected.
I received an iPad with a back light issue. usually i would pin it down to the fuse/filter. but every time the fuse is replaced i see a puff of smoke come from it as soon as the battery is connected. I have additionally replaced the IC/diode and the coil (I know its not the coil... but still). has anyone else encountered this if so is there a solution.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check the camera IC's. I had a heck of a problem with iPad Mini 1st gens popping filters and it ended up being a bad camera IC. I was popping them when I disconnected the screen and didn't figure it out until it was too late.
这个答案有帮助吗?
得分 0
1条评论:
hmm ok. i will check if i can find the camera ic. although i can't see how the back-light would be connected to the camera.
完成的
添加一条评论
添加你的答案
Thomas Edwards 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 9
总计 88
