跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac Speakers Wires and Pin Out
Few questions on the speakers:
1. What is the pin out for the four wires from each of the built-in speakers connecting to the logic board?
2. Where is the 17 watts amplifier powering the speakers, is it on the logic board or contained in the speaker units? In other words, can I hook up those speakers to an external source and have audio play through them at native volume levels?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Did you ever figure this out? I was considering attempting something similar with speakers from my 2013 iMac.
完成的
添加一条评论
4个答案
最有帮助的答案
here is the PINOUT for the Speaker Connectors on Logic board 820-2828
Update (06/21/2020)
here is picture
Update (06/21/2020)
Dear friend,
Thank you very much for your great news.
About speaker, sorry that it can not support the original iMAC speakers . As it can not provide enough power. But it can support the 5W 8ohm speaker instead. Will this give you the answer?
Hope you enjoy shopping with us all the time.
Have a great day!
这个答案有帮助吗?
得分 4
24条评论:
I was hoping to do repurpose the speakers in a 2013 iMac. they were redesigned from these models; any chance you have the pinout info for those versions? it would be tremendously helpful! Thanks in advance!
完成的
no.
google search for the schematic.
2013 iMac is not enough information.
完成的
Do you add a CROSSOVER PCB?
完成的
@ant3 I apologize for the delay, I didn't get a notification and only checked back now. I'm new to this kind of project, so please forgive my ignorance of others the terminology and the process. The bottom line is that I decided to upgrade from my 2013 27" iMac, but wanted to try to undertake the process of converting it into an external display. Fortunately there are plenty of kits available for that, and I found one for my specific panel with little trouble. However, I started wondering what else could be repurposed, such as the speakers and even the webcam. Anyway I know each speaker has six pins, and I still have the logic board, but I haven't tried tracing those pins to see what they correspond to yet. I'm not familiar with Crossover PCBs, but I'm assuming it would be a board that connects to these two speakers and translates the audio signal from a normal audio output into something that the speakers understand? Similar to the kit I purchased for the LCD display itself? Thanks in advance!
完成的
https://www.digikey.com/product-detail/e...
https://www.ebay.com/itm/2-Audiopipe-Pas...
iMac 4 pin connector Right Speaker
pin1- black wire -woofer +
pin2 -gray wire -woofer -
pin3- brown wire- tweeter +
pin4- gray wire - tweeter -
iMac 5 pin connector Left Speaker
pin1- black wire- woofer +
pin2-gray wire- woofer -
pin 3 no connection
pin 4 - brown wire- tweeter+
pin5- gray wire tweeter=
完成的
显示更多的19条评论
添加一条评论
Searching for "K62 mlb" on google gives the iMac 27" main logic board's schematic diagrams. Finding any pinout from that is pretty straightforward.
这个答案有帮助吗?
得分 0
添加一条评论
I bought these 8 ohm/5W speakers on ebay, since the seller of the LCD controller board said they would work.
I plugged in and they did NOT work.
I checked the pinout and then swapped the black and read wires and plugged in and they did NOT work.
http://www.vslcd.com/Specification/M.NT6...
https://www.ebay.com/itm/1-Pair-8-ohms-5...
这个答案有帮助吗?
得分 0
1条评论:
What type of cable are you connecting to the board? I mean hdmi, dvi, vga or any other. I just ask this because dvi, for example, doesnt give you any sound output :/
完成的
添加一条评论
Board 820-3299
Link to PDF complete schematics:
https://mega.nz/file/Pt1gWK4T#OHhahr27U8...
Furthermore, if you want have a good audio, make use of HDMI connector and an 20+20W board:
https://it.aliexpress.com/item/100500401...
HTH
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vijay Anand 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 47
过去 30 天: 108
总计 6,905
