跳转到主内容
Android's 4.4 OS with a 1600 x 2560 pixel resolution.
45 个问题 查看全部
Wifi and bluetooth button wont turn on how do I fix this
Yesterday morning my tablet wifi turned on automatically & connected to the internet without problem. By late afternoon, I tried to open my web browser and it said no internet connection. I cked the wifi to make sure it was on, to find it was off. When I tried turning it back on, the button remained grayed, and then went back to the off position. I tried the same thing with the bluetooth button, with the same results. I did a hard reset, wipe cache, and a factory reset with no success. Ive seen others have had the same issue with the lollipop OS upgrade as I am having now. Has there been a fix available that will work other than flashing it back to the original kit kat OS?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check your baseband version and be sure it matches your software version. When I upgraded to Lollipop using Kies, it failed to upgrade the baseband and wifi stopped working. I used Odin to install a different Lollipop package and it upgraded baseband as well. Wifi started working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cynthia Sibblies 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 508
