跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
208 个问题 查看全部
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
answer is not even about the hinge, only addresses the easy answer
完成的
添加一条评论
3个答案
最有帮助的答案
Microsoft Surface RT Kick-stand Replacement
这个答案有帮助吗?
得分 2
4条评论:
answer does not address the broken hinge!
完成的
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
完成的
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
完成的
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
完成的
添加一条评论
not helpful--hinge broken & not the stand
这个答案有帮助吗?
得分 2
添加一条评论
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Grant Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 15,561
