跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Why can't I screw the bottom right P2 screw back in place?
Hi Guys! First of all thanks for all the support this great community provide.
I've got an issue with the loudspeaker of an Iphone 5c I'm fixing - sometimes it stops working- and I hardly suspect this is due to the lack of the bottom right P2 screw, which can't hold in place the speaker onto its contacts.
I've already bought new screws to replace the missing one, but when I've tried to screw it in place, it couldn't fit (I've also tried moving the original left one, into the right hole, but with the same result).
What can I do? Is there a replacing part for the P2 screws housing?
Thank you all!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check the front display assembly at the lower part. There are two screw holes for the pentalobe screws. If one or more is missing, the missing sides will just have the screws spinning to nothing.
If they are both there then you will probably need to poke something through a bit then close then put the screen back in place and try again.
There is no easy replacement for the P2 pentalobe screw holes as they are part of the front display screen frame.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for your answer! Is surely helpful :)
Luckly the display assembly seems to be fine, even 'cause the issues still remain without the display assembly...
May it be due to the lightning connector housing? in that case, is there a part just for it, or should I change all the connector?
完成的
I doubt the dock connector would be at fault because it shouldn't obstruct where it goes unless the whole phone housing is badly damaged / bent at the bottom part.
完成的
添加一条评论
添加你的答案
Rocco Lorusso 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 156
