跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Short circuit in iPhone charger
Hello,
The sequence of events: Came home with a dead phone, see two new chargers on the table (brother got from Aliexpress),and quickly putit to charge. I left phone to charge. After aprox. 2 hours of charging I took phone in hands and see that it charged to 100% and in the mean time I pressed home button and something happened in the wall socket where it was plugged in. It sparked and smoked a bit, so I quickly put the cord out.
It looked like everything is normal, but since then my phone is not charging, because it always shows '' This ACCESSIORIES may not be supported '.
That charger was unfortunately fake, but even if I use my original it shows the same.
Now it can be charged only when it is switched off and battery empty very quickly.
But it is recognized in itunes normally.
I changed the battery, restored it, clean up dock connector, tried restart it, etc. etc.
The phone is no longer under warranty.
Does anyone have any idea what could I do?
Thank you to everyone who could help me,
Andraz
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I will try and report how things will go. Thanks for help
完成的
Hey everyone, i'm new here. So, i want to know the next. Today i was about to charge my iPhone, and when i plugged in my apple charger into the electric current, and it made a short circuit! it lighten from inside and started to smell like burned wires and won't work, the phone was connected and is not waking up
完成的
添加一条评论
4个答案
已选择的解决方案
I guess you could try replacing the dock connector and try using a quality phone wall charger and lightning cable.
这个答案有帮助吗?
得分 1
添加一条评论
If replacing the dockConnector doesn't help, it is likely a problem with the charging circuit on the logicboard. You will need a real professional to replace therevalent chips.
这个答案有帮助吗?
得分 1
添加一条评论
How to check i phone 6 charging port shorting
这个答案有帮助吗?
得分 0
添加一条评论
Marta dump-truck in the flesh
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andraz Reich Pogladic 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 53
总计 11,483
