跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
Why can't I loosen the adhesive to remove the speaker covers?
I'm trying to remove the speaker covers on my HTC One M8. I heated an iOpener for 60 seconds and then let it sit on the speaker cover for 90 seconds. I then tried to remove the cover with a plastic opening tool but it wouldn't come out. What am I doing wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Nothing you're doing wrong, they're just stubborn. I used a hair dryer on mine, the glue eventually softened up enough. New covers can be had for just a couple of dollars, so don't necessarily try too hard to preserve them (they'll likely not sit right again after removal anyway -- new covers come with adhesive attached, so they're perfectly flat, and just need to be applied).
Now, that said, there is a black raised lip around the outer edge. When I opened mine the first time, I didn't understand which side of that should come apart, and did some damage to it (nothing functionally wrong, but cosmetic, and it bugged me). The lip goes around the speaker covers, but no deeper, so to separate from the metal back, go around the outside of the lip, not the inside. This is probably obvious, and I was just being dim, but, just in case, keep an eye out, as it's incredibly easy to break off pieces of that ridge.
One more unsolicited tip I got off an unrelated repair video: the power button isn't attached to anything, and is obnoxious to try to replace once it falls out, but a small piece of tape over top of it keeps it in place, so it's no problem.
Good luck with your repair! :O)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matthew Eng 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 246
