跳转到主内容
加入维修社区 - 创建账户
The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
Why is blue light blinking
blue light ay icon blinking. I can scan and copy but can't print documents form the computer
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
hey,
Possible problem: network connection between pc and printer ( i have the same model , and i had the same problem) check network connection and config.
Kind regards
Kevin
这个答案有帮助吗?
得分 1
3条评论:
all cables connected. installed new router and tried netgear IP update for HP. Old dog new tricks In other words I don't have much experience here
完成的
hey no worries : check if the printer recognize the network. check if your laptop or pc recognize the printer (as standard printer). I don't know if your familiar with the ping command in cmd? if you have the IP number of the printer you can try the ping command .. so you'll know if the printer talks to the pc..
Do you get other info on the dispaly of the printer? or the pc? an error or something.
if you installed win 10 ( update) lately, remove the printer ( full remove) and install it again. I heard a lot of printer problems since win 10..
Kind regards,
Kevin
完成的
did you tried wireles as wel?
完成的
添加一条评论
why is Blue light blinking at icon? I Can copy and scan but cannot print documents from computer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jpadgitt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 35
总计 2,056
