跳转到主内容
The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
39 个问题 查看全部
Can I use a different model to replace the LCD?
Okay, I have the Verizon version of S4 SCH-I545. The LCD needs to be replaced. I also have available a working LCD from the ATT I337 S4 which includes the frame. I read that they have different frames and home flex so you can't just use any version to replace LCD.Can I just switch the LCD to the Verizon model motherboard?.Do all the motherboards match up? Can I just transfer all the parts to the I337 LCD frame? Or is the home flex connection different on the verizon motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
It says that the S4 active is AT&T only... Is it unlocked?
完成的
添加一条评论
2个答案
已选择的解决方案
No. The Samsung Galaxy S4 screen is completely different from the Samsung Galaxy S4 active screen. Neither will work on the other.
这个答案有帮助吗?
得分 2
1条评论:
Are all the ATT S4's using an active screen? I don't know if mine is active.Anyway to check?
完成的
添加一条评论
yeah i have a galaxy a50 and the model is a505U and i used a a505f, it was working fine at first then vertical lines started appearing. it’s most likely because the different models.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
xsilicon9 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 1,469
