跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Multiple Problems with the iPhone 4s
This will probably sound very confusing, and probably never heard of, but i'll try my best to explain.
I came home one night, and my phone didn't automatically connect me to wifi, so I went to my settings and went to connect to wifi, but it was acting a bit slow and would freeze for a second or so. Once I did connect, it only lasted about 30 seconds before I was disconnected. I tried again and it did the same thing, connect for 30 seconds than kicked me off. When I went back to re-connect, it couldnt find any networks to connect to, usually when this happens i turn off the wifi and turn it back on, but this time it never turned back on, and I couldn't do anything besides open up my assistive touch and play with those options, the home and power button didnt do anything in the assistive touch.
I force shut down my phone using the assistive touch power button and the actual home button, and it goes to an apple screen, and stays there until i open the back and uplug the battery and put it back in. Once i do that it still does the same thing over and over, no fix whatsoever nor could I find any solutions online.
Does anyone think they can help me? or is it just time to get a new phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I think the system software has gone bad? Have you tried restoring or upgrading it?
完成的
I've tried upgrading it, still doing it
完成的
添加一条评论
1个答案
已选择的解决方案
Have you tried a soft reset on the phone? Hold down the home button and the power button. Normally this will take care of a lot of issues. Also, the less space you have on your phone, the glitchier it will be.
If all else fails, plug it into iTunes and see if it can be repaired or restore if need be.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kangaroofilms 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 209
