跳转到主内容
Nikon D600 24.3 MP CMOS FX-Format Digital SLR Camera
16 个问题 查看全部
How do I open this ZIF? Connector?
Hi,
This is the underside of top of my D600 that I dropped. To mend the top display I had to remove this board and do some soldering.
I pulled out the ribbon that goes into the white connector at the bottom of the board as you view it - see attached photos.
I pushed back the ribbon, although it did no go completely in. After re-assembling the camera I found the wheel under the forefinger inperative.
How do I unlock this, I have so far not tried too hard as I must not break it!
hope someone can help,
John
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
every zif connectors have a plastic lock on it, just unlock with a small flat screw driver and pull out the ribbon cable carefully, when reconnecting extreme care should be taken.
这个答案有帮助吗?
得分 0
添加一条评论
The black part of the connector is the part that flips up to release the ribbon cable. Still be gentle with it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Bishop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 432
